KIT HI END FOSGATE PERFEITO. PARA QUEM É REALMENTE EXIGENTE.
NÃO DISTORCE.
ACOMPANHA OS CABOS FOSGATE TAMBÉM.
EU NÃO TENHO MAIS A CÚPULA PROTETORA DOS FALANTES POIS EU OS USAVA DENTRO DA PORTA.
TODO O RESTANTE ESTÃO EM PERFEITO ESTADO, FALANTES, CROSSOVER E TWITER.
O PORTA FUSIVEL E FUSIVEL NÃO É MAIS O DA FOSGATE.
TENHO 2 PARES DO KIT 2 VIAS MAIS OS CABOS.
TENHO TAMBEM UM SUBWOOFER KICKER L7 750 WRMS.
CONSULTE MEUS ANUNCIOS. FAÇO UM VALOR BOM NO CONJUNTO.
6-1/2" T1 Series 2-Way Component System
Power Handling:
Peak: 400 watts per set / 200 watts each side
RMS: 200 watts per set / 100 watts each side
Recommended Amplifier RMS Power: 30-100 watts
Carbon fiber and polypropylene injection molded cone
Butyl rubber surround
1" Aluminum dome tweeter with polyurethane suspension
Tweeter has 3 levels of attenuation
On-axis/off-axis tweeter configuration
Positive Temperature Coefficient (PTC) Protects the tweeter with a bypass resistor
Discreet Dual Clamp (DDC) Tweeter mounting system for simplified installation
FlexFit basket design allows for variable mounting positions
VAST surround provides up to 25% more surface area of the cone
Bi-amp on/off capability
External audiophile grade component crossover
5% tolerance high quality poly-capacitors and air-core inductors
4 ohms impedance
1-1/16" Voice coil
Speaker grilles included
Includes an OEM 6" x 9" and 5" x 7" adapter plate for simple installation.
VENHA CONFERIR.
PARA QUEM CONHECE E GOSTA SABE DA QUALIDADE.
TEL: 11 98146-7442
TEL: 11 4805-2402
http://imageshack.com/a/img673/4779/zJbt4W.jpg
http://imageshack.com/a/img910/3070/Ff9Wqu.jpg
http://imageshack.com/a/img903/4640/0M15im.jpg
APENAS VENDA. NÃO INSISTA.
VENDO 2 Kits 2 Vias 6 Rockford Fosgate T1652s + Cabos Fosgat
Re: VENDO 2 Kits 2 Vias 6 Rockford Fosgate T1652s + Cabos Fo
Ainda tem o Kit? Obrigado.
